saarus
#1 Posted : Monday, October 12, 2009 7:41:15 AM(UTC)
saarus
Hi,
My dryer was working great, and yes it is probably old but still in great condition. I was doing running and went to check on it, and the timer was still at half way, and the machine was completely stopped. Have tried other settings, but when I turn the on know all I get is a click sound from the "board" area (sorry don't know the name). Any ideas?
thanks
-d
#2 Posted : Monday, October 12, 2009 7:19:13 PM(UTC)
Check if there is 240 VAC to the dryer.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE FSE747GES1 | AppliancePartsPros.com
saarus
#3 Posted : Monday, October 12, 2009 8:07:49 PM(UTC)
saarus
Thanks for replying, but what does 240 vac mean? I tried switching the door panel to the other side (right open or left open) to see if maybe the switch was bad, but it still didn't turn on.
-d
#4 Posted : Tuesday, October 13, 2009 4:26:40 PM(UTC)
You have to have a simple voltmeter to check the voltage at the dryer wall outlet.
saarus
#5 Posted : Tuesday, October 13, 2009 4:29:14 PM(UTC)
saarus
Hi,
The light inside the dryer comes on when it is plugged into the outlet, or does this mean nothing?
-d
#6 Posted : Tuesday, October 13, 2009 4:53:25 PM(UTC)
The light bulb as well as the motor needs just 120 VAC while the heating element needs 240 VAC.
saarus
#7 Posted : Tuesday, October 13, 2009 5:04:14 PM(UTC)
saarus
OK, will go get one tomorrow.
Is it possible to take the "control board" and have that tested?
#8 Posted : Tuesday, October 13, 2009 5:07:19 PM(UTC)
I did not see any control boards for this model.
saarus
#9 Posted : Tuesday, October 13, 2009 6:27:28 PM(UTC)
saarus
I was talking about where all the knobs connect to inside the machine.
#10 Posted : Wednesday, October 14, 2009 9:02:21 PM(UTC)
Lets do it step by step, one thing at a time.
