wastikan
#1 Posted : Friday, February 1, 2008 2:23:15 PM(UTC)
wastikan
How Do I Adjust The Belt On My Maytag Atlantis Or Tighten The Belt.
fyxer
#2 Posted : Friday, February 1, 2008 7:06:59 PM(UTC)
fyxer
There is no adjustment that i know of, what i have noticed is that like everything else these days these belts are made of cheaper quality material compared to the older maytag washers the ones that use two belts so if your machine is used a lot you can just buy another two or three belts and keep as spares.
richappy
#3 Posted : Saturday, February 2, 2008 1:17:58 AM(UTC)
richappy
Check the plastic tranny pulley, might have a burnt spot.
If ok, check the motor mount rollers and clean if necessary, they might be sticking and preventing proper tension on the belt.
wastikan
#4 Posted : Tuesday, February 19, 2008 8:47:30 AM(UTC)
wastikan
the washer fills but it does not agitate or spin or drain at all. and the motor plastic which holds the belt broke off.:confused:
Guest (5)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
Maytag atlantis half works (Dryer Repair)
by BDR1783 5/3/2024 1:04:26 AM(UTC)
Maytag Atlantis MAV7700AWW motor? (Washer Repair)
by Guest 4/1/2023 7:45:13 AM(UTC)
Kit 12002213 for Maytag Atlantis washer MAV7600aWW (Washer Repair)
by Shaun W 2/12/2021 7:34:30 AM(UTC)
Maytag Atlantis washer - MAV6200AWW (Washer Repair)
by Tidasu 1/17/2021 10:06:08 PM(UTC)
Maytag Atlantis agitates during spin cycle (Washer Repair)
by Brent99 9/15/2020 10:38:11 AM(UTC)
Maytag Atlantis MAV7700AWW Washer occasionally not dumping water (Washer Repair)
by pzazzera 6/30/2019 7:37:02 AM(UTC)
Maytag Atlantis Dryer Ignites, Blows Gas/Flame then shuts off (Dryer Repair)
by pzazzera 5/16/2019 6:19:39 AM(UTC)
Maytag Atlantis Will Not Run (Washer Repair)
by Bsktbll 10/28/2017 5:29:38 PM(UTC)
Maytag Atlantis Washer is dead and full of water (Washer Repair)
by mtaylor4242 1/28/2016 2:57:43 PM(UTC)
Maytag Atlantis Washer will not spin (Washer Repair)
by lvavis 8/26/2015 7:56:10 PM(UTC)
Alternate timer for Maytag Atlantis dryer (Dryer Repair)
by thorning 7/21/2015 1:37:27 PM(UTC)
Maytag Atlantis only spins on high speed (Washer Repair)
by davidsg99 6/1/2015 9:07:15 PM(UTC)
Maytag Atlantis new timer not working (Dryer Repair)
by blewis123456 11/5/2014 8:26:45 AM(UTC)
Maytag Atlantis Dryer timer which one? (Dryer Repair)
by Stevenerd 10/21/2014 9:52:18 AM(UTC)
