curtisn
#1 Posted : Saturday, October 3, 2009 6:34:59 PM(UTC)
curtisn
My gas oven stopped working the other day after working fine. I called a repair person and he wanted big bucks to repair $$$ (more then the oven is worth). He said it needed both a timer (i assume a control bd) and a oven sensor. Does this sound right? The control board seems to work, burners will not come on.
Is there any way I can test the existing parts to run out why it will not heat up?
Thanks in advance
SublimeMasterJW
#2 Posted : Saturday, October 3, 2009 6:56:32 PM(UTC)
SublimeMasterJW
ApplianceJunk
#3 Posted : Saturday, October 3, 2009 10:10:33 PM(UTC)
ApplianceJunk
Hi,
What burners do not come on?
Bake, broil, top burners?
curtisn
#4 Posted : Sunday, October 4, 2009 5:16:44 AM(UTC)
curtisn
Top side of range works-only ovens does not work. All indicators come on - on control panel to indicate it is working correctly. However, it never heats up ---this is a GAS range not an electric range
SublimeMasterJW
#5 Posted : Sunday, October 4, 2009 6:19:55 AM(UTC)
SublimeMasterJW
Everything in the circuit must have continuity for the oven to fire up. What if the ignitor glows but the oven will still not come on? If the ignitor is glowing that would mean you have a circuit. Solution: Replace the ignitor, even if it comes on. Why? Because 99% of the time the ignitor is weak. When it is working fine it should be so bright you cannot look at it for long. If it is a mellow orange color it is bad, replace it. The only way the gas oven valve
would be bad is if it is open and has no continuity. That goes for the control as well.
Check out this simple diagram of how a basic gas range operates.
UserPostedImage
oven ignitor
An ignitor must draw at least 3.5 amps or that safety valve will not open up and release the gas:
. Click on image to see it in motion
A typical late model gas range manua
l
curtisn
#6 Posted : Wednesday, October 21, 2009 6:26:57 AM(UTC)
curtisn
I replaced the control assembly and oven started working correctly-so I guess it was worth paiding the tech for the service call he was right on the money
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 7:09:48 PM(UTC)
GE gas oven not heating (Oven Repair (including Ranges and Cooktops))
by 1alembic 4/4/2018 5:59:05 PM(UTC)
Gas Oven not heating correctly (Oven Repair (including Ranges and Cooktops))
by Malumake 2/2/2014 2:26:10 PM(UTC)
by csulzbach 11/24/2012 1:34:07 PM(UTC)
GE Gas Oven not heating up correctly (Oven Repair (including Ranges and Cooktops))
by ichengsd 6/19/2012 4:05:19 PM(UTC)
Gas Oven not Heating at all burners OK (Oven Repair (including Ranges and Cooktops))
by tattell 2/7/2012 12:01:59 PM(UTC)
Amana ARGS7650 Gas Oven not heating (Oven Repair (including Ranges and Cooktops))
by reg71 10/28/2010 8:49:05 AM(UTC)
Please Help!! Whirlpool gas oven not heating correctly (Oven Repair (including Ranges and Cooktops))
by Rebetimm 7/21/2010 9:24:45 AM(UTC)
Gas oven not heating properly (Oven Repair (including Ranges and Cooktops))
by wandanyb 3/17/2010 4:47:18 PM(UTC)
Gas oven not heating at all! (Oven Repair (including Ranges and Cooktops))
by krakka 8/14/2008 3:02:27 PM(UTC)
Older Gas Oven not heating up enough (Oven Repair (including Ranges and Cooktops))
by Meg70 2/10/2008 1:56:14 PM(UTC)
gas oven not heating up like it should (Oven Repair (including Ranges and Cooktops))
by fillhardfarm 1/29/2008 9:47:01 AM(UTC)
Gas Oven Not Heating (Oven Repair (including Ranges and Cooktops))
by defirechief8915 10/24/2007 5:33:28 AM(UTC)
