celtmann
#1 Posted : Wednesday, September 23, 2009 9:23:23 AM(UTC)
celtmann
At the end of the rinse cycle, the washer does not go into spin and the timer indicator light goes blank . It does not display an error code.
sidfink43
#2 Posted : Friday, September 25, 2009 5:31:11 AM(UTC)
sidfink43
I can not get your model to come up, can you check the model number.
If this is a front load washer the likely suspect is your motor control/speed control board.
celtmann
#3 Posted : Friday, September 25, 2009 5:34:52 AM(UTC)
celtmann
GLTF 2940 ES is the model number. I too think that it is the board because it doesn't give an error code as it does when the coin catcher is full.
sidfink43
#4 Posted : Friday, September 25, 2009 6:07:07 AM(UTC)
sidfink43
Use this service manual to see if you can put it into troubleshooting mode.
http://frigidaireservicetips.co...rizontalAxisWasherSM.pdf
You have a control board and a motor/speed control board and since they are expensive you want to make sure you are replacing the right one. Since it will go through the wash cycle I suspect it is the motor/speed board.
celtmann
#5 Posted : Friday, September 25, 2009 6:10:42 AM(UTC)
celtmann
Thanks for your help
Guest (6)
Samsung Washer does not spin (Washer Repair)
by SwimKatie 3/22/2016 5:51:48 PM(UTC)
Frigidaire Front Washer does not spin - intermittent issue (Washer Repair)
by jamesm113 6/23/2015 9:13:55 PM(UTC)
Kenmore 90 washer does not spin (Washer Repair)
by ChdoulaDIY 5/31/2015 1:39:29 AM(UTC)
by RoyD 10/15/2014 10:24:49 AM(UTC)
Washer does not spin or agitate (Washer Repair)
by bluebomb 8/8/2013 4:55:43 AM(UTC)
washer does not spin or agitate (Washer Repair)
by Dustycopper 2/10/2013 1:49:54 PM(UTC)
Stackable washer does not spin or drain (Washer Repair)
by North Dakota 1/23/2013 7:00:40 PM(UTC)
by isagrace 1/23/2013 9:40:41 AM(UTC)
GE Profle Washer Does Not Spin (Washer Repair)
by cclemm 11/13/2012 7:56:17 AM(UTC)
Amana Washer Does Not Spin (Washer Repair)
by sfrane 10/29/2012 11:21:24 PM(UTC)
Washer does not spin anymore just normal draining speed (Washer Repair)
by Herbert Engelmayer 9/13/2012 1:29:52 PM(UTC)
maytag washer does not spin fast after rinse cycle (Washer Repair)
by pepito 6/28/2012 3:31:14 PM(UTC)
frount load washer does not spin to full speed (Washer Repair)
by ranger11986 6/12/2012 3:07:50 PM(UTC)
washer does not spin/agitate (Washer Repair)
by jetson2k 5/7/2012 2:31:02 PM(UTC)
washer does not spin/wash clothes (Washer Repair)
by leonitise 1/28/2012 9:17:45 PM(UTC)
