2 Pages12>
dustin1976
#1 Posted : Sunday, September 20, 2009 9:43:18 AM(UTC)
dustin1976
Couple days ago I noticed my ice in the maker was melting down into to the bottom of the freeze. Looking further I noticed that both sides are not cooling well. I have cleaned the coil in the back so far and checked for air leaks. THer is also frost building up on the back wall, the ice tray has water but will not freeze and dump. PLease help , thanks
applianceman
#2 Posted : Sunday, September 20, 2009 3:46:20 PM(UTC)
applianceman
[FONT='Times New Roman']Remove the back cover that has the ice build up and melt all the ice of the coils. More than likely the defrost heater caused the ice to build up. You can check the heater with an ohmmeter and if it is open replace it. [/FONT]Refrigerator repair guide
dustin1976
#3 Posted : Sunday, September 20, 2009 4:22:00 PM(UTC)
dustin1976
Thanks so much! I'm on it, hope this does it.
dustin1976
#4 Posted : Tuesday, September 22, 2009 8:56:14 AM(UTC)
dustin1976
ANy idea if my fridge is after 2002 model ?
dustin1976
#5 Posted : Tuesday, September 22, 2009 9:04:24 AM(UTC)
dustin1976
I tested the fridge with an old tester plugged in the wall/fridge plugged in the tester. Current was there so heater is good ?
applianceman
#6 Posted : Tuesday, September 22, 2009 7:09:44 PM(UTC)
applianceman
Yes, yours is a 2002 or newer model.
I don’t quite follow the test you are saying you did.
applianceman
#7 Posted : Tuesday, September 22, 2009 7:14:55 PM(UTC)
applianceman
I am assuming you just did an amp test, am I correct?
If so it doesn’t prove the heater is bad or good. Unless you know the refrigerator was in defrost and the current flow was relatively high (8-10 amps or so). Even then it wouldn’t necessary prove it.
dustin1976
#8 Posted : Friday, October 30, 2009 2:29:24 PM(UTC)
dustin1976
What would u try to replace 1st ? Defrost thermostat or one of the 2 sensor temp ? Looks like I'll save money even if I replace both. Thanks
applianceman
#9 Posted : Friday, October 30, 2009 2:49:38 PM(UTC)
applianceman
The defrost heater would be the first thing I would try unless you tried that already and it didn’t work or tested it with an ohmmeter.
The next thing would be the senor.
There are pictures on this page that will help identify faulty sensors and defrost thermostats. GE Refrigerator Repair Guide
dustin1976
#10 Posted : Saturday, October 31, 2009 7:05:25 AM(UTC)
dustin1976
OK , I have searched my model # Gss22ifpaww. Models with the same model # except for the last 3 digits pop up and take a #ah1993872 defrost heater. I call GE and get a #wr51x1053 from they're people. Trying to see if thats the same part with different #'s depending on vendor. GE is more expensive to order from if so. Thanks for any help
Guest (7)
2 Pages12>
