sparkebk
#1 Posted : Tuesday, September 15, 2009 7:38:22 AM(UTC)
sparkebk
Guys, our GE Microwave model: JVM3670SF02 was accidently run (won't say who but it was the wife) without any food in it till it went dead. Since its a fairly new model, can I assume that it blew the internal fuse (no display lights are on)? Where would the fuse be located and can I get to it from the bottom myself (since its cabinet mounted)?
Your thoughts?
thanks
applianceman
#2 Posted : Tuesday, September 15, 2009 9:28:05 AM(UTC)
applianceman
Unplug microwave and remove the front griddle. Once done you can get to the screws that hold the control panel on and remove the control panel. Once done you should be able to see the fuse. Hope this helps. Microwave Repair Guide
sparkebk
#3 Posted : Tuesday, September 15, 2009 10:25:19 AM(UTC)
sparkebk
Thanks, thats just the one fuse #AP2631556 correct? Also, when you say the front griddle, your talking about the frame around the front display and push buttons? Sorry, just want to make sure...thanks
applianceman
#4 Posted : Tuesday, September 15, 2009 1:53:55 PM(UTC)
applianceman
Yes, that is the fuse I was talking about however, there is a thermostat that may have overheated. Check the fuse first because you have to take the microwave down to check the thermostat.
The griddle is the vent that goes across the top of the microwave and the control panel is the part with the buttons.
sparkebk
#5 Posted : Friday, September 18, 2009 7:30:28 AM(UTC)
sparkebk
Well, was able to get the griddle and control panel off, replaced both fuses, plugged it back in and no lights or display came on. Anything else I should try. What else would keep it from getting power?
applianceman
#6 Posted : Friday, September 18, 2009 9:53:38 AM(UTC)
applianceman
There is a thermostat on top of the microwave that probably overheated. You will have to take the microwave down and remove the case to access the thermostat. This page will help http://www.appliance-repair-it.com/GE-spacemaker-microwave.html I know you are not replacing the magnetron tube but that page will help with disassembly.
Ge profile microwave looks like working but no heat and turntable does not turn (Microwave Repair)
by Sdemirpolat 11/8/2015 4:35:13 PM(UTC)
GE Profile microwave oven (Microwave Repair)
by alpinebucks 6/13/2013 12:47:08 PM(UTC)
GE profile microwave turns on will not heat (Microwave Repair)
by JOHNWIN69 5/13/2013 5:10:08 PM(UTC)
GE Profile Microwave - DOESNT HEAT (Microwave Repair)
by VentureRider 2/3/2013 1:00:32 PM(UTC)
GE Profile Microwave (Microwave Repair)
by Robak 12/30/2012 7:12:57 AM(UTC)
GE Profile Microwave Not Heating on Microwave or Convection Mode (Microwave Repair)
by stampede 11/8/2012 6:30:50 AM(UTC)
GE Profile microwave oven - replacing the board latch (Microwave Repair)
by srduff1977 11/5/2012 9:46:52 AM(UTC)
GE Profile Microwave stopped heating food. (Microwave Repair)
by jackief288 9/4/2012 8:30:08 AM(UTC)
GE Profile Microwave mod# JE2160SF03 no heat (Microwave Repair)
by donmisc09 11/16/2011 7:41:06 PM(UTC)
GE Profile Microwave not heating (Microwave Repair)
by jniggli 7/15/2011 7:21:44 AM(UTC)
GE Profile Microwave Door Adjustment (Microwave Repair)
by patoca 4/22/2011 8:32:29 PM(UTC)
GE Profile Microwave lost power (Microwave Repair)
by semiturbo 4/22/2011 9:34:25 AM(UTC)
GE Profile Microwave won't heat? (Microwave Repair)
by bill007 3/3/2011 4:47:45 PM(UTC)
GE Profile microwave key pad not working (Microwave Repair)
by SDR P&H 1/2/2011 4:40:07 AM(UTC)
GE Profile microwave is dead after small fire inside (Microwave Repair)
by DILJA 12/27/2010 9:54:20 AM(UTC)
