2 Pages<12
kawfeeman
#11 Posted : Sunday, January 20, 2008 1:23:54 PM(UTC)
kawfeeman
do you have a wiring diagram....???
double door thermador
#12 Posted : Sunday, January 20, 2008 1:46:02 PM(UTC)
no, I do not have a wiring diagram.
kawfeeman
#13 Posted : Sunday, January 20, 2008 1:58:25 PM(UTC)
kawfeeman
sorry, there is no schematic/wiring diagram on the tech svc site for this model ...
#14 Posted : Tuesday, January 22, 2008 1:10:19 PM(UTC)
Is the selector switch push button style?
Also the model number you posted does not come up.
Verify and repost it, please.
#15 Posted : Tuesday, January 22, 2008 1:30:26 PM(UTC)
I was able to locate a working oven that is the same model as mine. I swapper out the thermostat controller (3rd controller from the right) and also swapped out the interior thermostat wand. And my oven now works. However, I need to purchase the swapped out parts to make the other oven work again.
MSC28-2 model
271208 serial
Double door, electric wall oven
control panel has a rectagular clock on left and 4 controller knobs, boilstat, selector and thermostat controls for the upper oven and a thermostat controller for the lower oven. On the far right of the control panel is a temperature dial.
I will need help in locating the nedded parts.
#16 Posted : Tuesday, January 22, 2008 1:39:57 PM(UTC)
All 4 controllers are dial type - not push button
kawfeeman
#17 Posted : Tuesday, January 22, 2008 8:34:51 PM(UTC)
kawfeeman
try Tdor direct as age of oven may be difficult to acquire parts
#18 Posted : Wednesday, January 23, 2008 12:50:52 PM(UTC)
If you can get the part number from the old one, it might help.
Oven Will not heat to temp. (Oven Repair (including Ranges and Cooktops))
by rtmeek 9/12/2022 12:32:58 PM(UTC)
Frigidaire FEFL79HQA Oven Will Not Heat (Broil or Bake) (Oven Repair (including Ranges and Cooktops))
by Allen_M 5/19/2022 8:57:30 AM(UTC)
Frigidaire - Oven will not heat up but burners work (Oven Repair (including Ranges and Cooktops))
by JohnGuerra 3/18/2020 12:45:12 PM(UTC)
Frigidaire gas oven will not heat (Oven Repair (including Ranges and Cooktops))
by HHG 9/6/2019 11:33:44 AM(UTC)
GE Profile Oven will not heat past 100, broiler works (Oven Repair (including Ranges and Cooktops))
by maribernj 2/16/2016 8:37:13 AM(UTC)
Oven will not heat (Oven Repair (including Ranges and Cooktops))
by couldcareless 11/11/2015 2:05:29 PM(UTC)
by davidwhop 8/31/2014 7:17:47 AM(UTC)
Double Wall Oven will not heat up (Oven Repair (including Ranges and Cooktops))
by jwmingus 11/12/2013 4:25:40 PM(UTC)
Frigidaire Left oven will not heat either element (Oven Repair (including Ranges and Cooktops))
by morang 9/27/2013 5:08:44 PM(UTC)
Thermador sc302t top oven will not heat (Oven Repair (including Ranges and Cooktops))
by bnastasi 6/9/2013 9:01:10 PM(UTC)
Lower and Upper Oven will not heat (Oven Repair (including Ranges and Cooktops))
by Igmike 4/22/2013 5:43:12 AM(UTC)
My Oven will not heat up on bake (Oven Repair (including Ranges and Cooktops))
by missy79 4/3/2013 9:59:06 AM(UTC)
Electrolux dual fuel range oven will not heat (Oven Repair (including Ranges and Cooktops))
by p.andrew 3/19/2013 8:47:44 AM(UTC)
by Pjcibulski 1/29/2013 2:00:44 PM(UTC)
Oven Will Not Heat (Oven Repair (including Ranges and Cooktops))
by badams1214 1/18/2013 12:14:24 PM(UTC)
2 Pages<12
