do you have a wiring diagram....???
no, I do not have a wiring diagram.
sorry, there is no schematic/wiring diagram on the tech svc site for this model ...
Is the selector switch push button style?
Also the model number you posted does not come up.
Verify and repost it, please.
I was able to locate a working oven that is the same model as mine. I swapper out the thermostat controller (3rd controller from the right) and also swapped out the interior thermostat wand. And my oven now works. However, I need to purchase the swapped out parts to make the other oven work again.
MSC28-2 model 271208 serial Double door, electric wall oven control panel has a rectagular clock on left and 4 controller knobs, boilstat, selector and thermostat controls for the upper oven and a thermostat controller for the lower oven. On the far right of the control panel is a temperature dial.
I will need help in locating the nedded parts.
All 4 controllers are dial type - not push button
try Tdor direct as age of oven may be difficult to acquire parts
If you can get the part number from the old one, it might help.
