I have a window unit that is freezing up. What could the problem be?
Originally Posted by: slipperychic ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have a window unit that is freezing up. What could the problem be? wihout alot of info hard to pinpoint a problem. is your filter clean,also is there air flow coming out of the unit. will the unit shut off it your turn the temp down. need a little more info.
If the unit is freezing up then the coils are probably dirty. So clean em up with a nice cooling coil cleaner. Ace hardware has a very nice product called foaming cooling coil cleaner. Another thing could be the thermostat is bad. Do this simple test: Dip the probe into a glass of ice water. This will make the compressor shut down. If the compressor continues to run then replace the thermostat. FYI: If the compressor runs constantly then sooner or later the whole ac will ice up.
