2 Pages12>
debhug
#1 Posted : Saturday, August 29, 2009 10:18:31 AM(UTC)
debhug
Washer works fine except agitator is just moving very little as if belt has jumped off need to know how to open the washer up to find out if thats the problem :confused: need suggestions plz 7 cycle 2 wash spin speed if that helps
applianceman
#2 Posted : Saturday, August 29, 2009 10:30:00 AM(UTC)
applianceman
We need the model number for more accurate advice but the first thing to do is to try to turn the agitator by hand and if you can turn it the agitator coupling is bad. Pull the agitator up and out of the washer. Once off the agitator is right under the agitator attached to the transmission shaft with a 7/16 bolt. Clothes Washer Repair Guide
debhug
#3 Posted : Sunday, August 30, 2009 10:30:46 AM(UTC)
debhug
The model number is WJSR2070B2WW the agitator isnt responding as it should and moves too much when on the off mode ....it seems that the belt is still in tact cant get the washer open to check for sure....it seems it has dislodged from what holds it in place ...hope u understand this explanation .....what do i do to get the agitator off to check for dislodging because it does move but not like it should ....tyvm for any help with this cant afford a repairman must attempt to fix this myself:)
applianceman
#4 Posted : Sunday, August 30, 2009 10:35:55 AM(UTC)
applianceman
This is the part I think is your problem Part Details - GE Coupling, Agitator, part number: WH49X10042
Just pull the agitator up and you should see this part. If your can turn it by hand it is bad.
debhug
#5 Posted : Sunday, August 30, 2009 10:44:03 AM(UTC)
debhug
i cant get agitator off it wont come up ...is there something i need to do besides just pullup on it ....thanks Debbie
applianceman
#6 Posted : Sunday, August 30, 2009 12:43:35 PM(UTC)
applianceman
No, it just pulls off but it may be hard.
debhug
#7 Posted : Monday, August 31, 2009 7:42:01 AM(UTC)
debhug
ok got the agitator off and the coupling screw or bolt is rusty ...when u said if i move it by hand its band...do u mean if i turn the whole thing its bad because the coupling isnt moving ...is it possible the agitator just worked itself loose from the coupling or jumped off ...its very dirty in there would cleaning it lock back into postion ???:confused:
debhug
#8 Posted : Monday, August 31, 2009 7:57:24 AM(UTC)
debhug
i removed the coupling and it and the transmission shaft is caked with what i assume is soap scum so am cleaning all components then going to try putting it back together..then will know if its the coupling ...but it only movrs in circle with transmission shaft it doesnt slide on its own
debhug
#9 Posted : Monday, August 31, 2009 8:17:51 AM(UTC)
debhug
alright i cleaned it all put it back on coupling and agitator all it is doing is slowly turning ...but it spins fine so im thinking its not the belt or the transmission ...would replacing the coupling make it move from side to side like its suppose to when its washing ?????
applianceman
#10 Posted : Monday, August 31, 2009 10:58:38 AM(UTC)
applianceman
Yes the coupling may be your problem. When you got the agitator off did you try to turn the coupling by hand? If it will turn by hand the coupling is striped out. Does this machine spin or are you only having problems with wash?
Cafe fridge keeps warming up. Help! (Refrigerator & Freezer Repair)
by Guest 6/28/2024 8:33:23 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Nursing Paper Review SOS: Help a Peer Out! (General Talk)
by Guest 6/19/2024 3:00:02 AM(UTC)
Diagnostic Code Help (I screwed something up) (Refrigerator & Freezer Repair)
by megarms 5/20/2024 7:30:54 AM(UTC)
Freezer Help from Whirlpool Unit (Refrigerator & Freezer Repair)
by Guest 5/15/2024 5:37:40 AM(UTC)
Door Switch Help With Samsung Microwave Model ME21M706BAS (Microwave Repair)
by clagrow 5/2/2024 6:28:45 AM(UTC)
Need Help Identifying Part Manufacturer (Oven Repair (including Ranges and Cooktops))
by anonymous24 5/1/2024 3:25:51 PM(UTC)
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 4/29/2024 9:08:28 AM(UTC)
Cant remove Samsung ice bin , need help please (Refrigerator & Freezer Repair)
by Orlando123 4/20/2024 10:55:35 AM(UTC)
help maytag comercial dryer (Dryer Repair)
by blackwell316 4/4/2024 5:05:48 PM(UTC)
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 3/18/2024 5:53:29 AM(UTC)
GE Frontload Washer - Trouble Shooting Help (Washer Repair)
by mahgnibb 3/14/2024 2:37:10 PM(UTC)
Help finding the right screws to secure the top panel. (Washer Repair)
by mikkel3906z 2/20/2024 12:30:41 AM(UTC)
Dishwasher electrical help (Dishwasher Repair)
by Guest 1/11/2024 4:35:37 PM(UTC)
Washer help please maytag (Washer Repair)
by Guest 12/13/2023 4:45:08 AM(UTC)
2 Pages12>
