skeezic3
#1 Posted : Thursday, August 27, 2009 8:13:03 AM(UTC)
skeezic3
Whirlpool oven stopped working after the cleaning cycle completed.
The oven and the cooktop are separate. The cooktop works fine.
Thank you.
Frank / APP Team
#2 Posted : Thursday, August 27, 2009 11:36:06 AM(UTC)
Frank / APP Team
Thank you.
Do you have any display in the clock?
skeezic3
#3 Posted : Thursday, August 27, 2009 11:55:01 AM(UTC)
skeezic3
Yes, the CLOCK and controls for the oven work. Just no heat.
Frank / APP Team
#4 Posted : Thursday, August 27, 2009 12:15:32 PM(UTC)
Frank / APP Team
Look and see if the bake element has any bubbles or holes in it. If nothing is obvious you'll need to use a volt/ohm meter to check to see if it's good or not. Make sure you remove power from unit before pulling out the element. Below is a link to a parts breakdown.
Model RS675PXGB15
skeezic3
#5 Posted : Thursday, August 27, 2009 4:52:51 PM(UTC)
skeezic3
Pulled the elements, they both had continuity and checked out at 28 OHMS. There are no bubbles or cracks in them.
Frank / APP Team
#6 Posted : Friday, August 28, 2009 7:29:32 AM(UTC)
Frank / APP Team
You'll need to remove back panel and look for burnt wire, also ohm out the below part, which is a thermal fuse.
After that you're probably looking at the electronic control.
Part number: AP3885687
skeezic3
#7 Posted : Friday, August 28, 2009 11:43:56 AM(UTC)
skeezic3
I am just checking for continuity or a specific resistance.
skeezic3
#8 Posted : Friday, August 28, 2009 11:43:56 AM(UTC)
skeezic3
Frank / APP Team
#9 Posted : Friday, August 28, 2009 12:04:26 PM(UTC)
Frank / APP Team
Continuity. Needs to be a closed circuit.
skeezic3
#10 Posted : Monday, September 21, 2009 1:02:25 PM(UTC)
skeezic3
I now have an oven! Thank you so much!! It was indeed the thermal fuse. Your service is awesome. My compliments to your knowledge and expertise.
