liquidoranges
#1 Posted : 16 years ago
liquidoranges
The four halogen lights all went out at the same instant. Fan continues to work. light switch relay is heard activating, but no lights.
Any ideas???
liquidoranges
#2 Posted : 16 years ago
liquidoranges
All four lights went off simultaneously. Wiring diagram indicates TWO transformers. is it likely these both failed at the same time, or is it a switch on the circuit board? pushing the light switch makes a relay on the board click as normal, but no lights.
I sure could use some advise, including how with my volt meter I could possibly test to determine which part is bad.
#3 Posted : 16 years ago
Check for 120 VAC to each transformer primary windings from the control board. If there is nothing wrong then check for 12 VAC from each transformer secondary windings. Post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL IH8432RS1 | AppliancePartsPros.com
liquidoranges
#4 Posted : 16 years ago
liquidoranges
Per the wiring diagram, I located the power from the control board (P14 & P15). The two transformers are fed from this single point of contact. Voltage is present. Power is going to the transformers. From the step-down side (12v) there is nothing. This would suggest both transformers failed simultaneously? The light switch relay on the board gets very hot (just for info)
#5 Posted : 16 years ago
Have you disconnected the light wires from the transformers before measuring low voltage?
liquidoranges
#6 Posted : 16 years ago
liquidoranges
yes, single plug between transformers and lights: one transformer for each two lights. tested voltage with switch on, probing contacts at plug.
#7 Posted : 16 years ago
Looks like both transformers have gone bad.
- The transformer Part number: AP3846624
liquidoranges
#8 Posted : 16 years ago
liquidoranges
thanks very much for your help!
#9 Posted : 16 years ago
