FI62
#1 Posted : 16 years ago
FI62
I have a Maytag gas range model MGR5755ADQ and am having a problem with the oven.
It's slow to light, some times takes 2 or 3 attempts. Also it will not come up to temperature. With the digital control set at the highest temp (550) it will only get to 200 degrees.
What do I need to replace to fix this problem? thanks in advance Rich
jcmsp062@aol.com
FI62
#2 Posted : 16 years ago
FI62
To the top
#3 Posted : 16 years ago
Most likely the problem is a bad Bake igniter.
- The oven igniter Part number: AP4096256
Maytag oven problem (Oven Repair (including Ranges and Cooktops))
by kapittma 13 years ago
by hoof140 14 years ago
Maytag Oven problems (Oven Repair (including Ranges and Cooktops))
by kevinw3 16 years ago
