FI62
#1 Posted : Monday, August 3, 2009 9:13:05 AM(UTC)
FI62
I have a Maytag gas range model MGR5755ADQ and am having a problem with the oven.
It's slow to light, some times takes 2 or 3 attempts. Also it will not come up to temperature. With the digital control set at the highest temp (550) it will only get to 200 degrees.
What do I need to replace to fix this problem? thanks in advance Rich
jcmsp062@aol.com
FI62
#2 Posted : Thursday, August 6, 2009 12:36:19 PM(UTC)
FI62
To the top
#3 Posted : Thursday, August 6, 2009 5:03:33 PM(UTC)
Most likely the problem is a bad Bake igniter.
- The oven igniter Part number: AP4096256
Maytag oven problem (Oven Repair (including Ranges and Cooktops))
by kapittma 8/28/2012 9:20:45 AM(UTC)
by hoof140 11/23/2010 10:01:05 AM(UTC)
Maytag Oven problems (Oven Repair (including Ranges and Cooktops))
by kevinw3 6/15/2009 12:04:33 PM(UTC)
