Originally Posted by: junkyard38 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Amanna Gas range oven heating problems/ Amanna Model ARG7600WW P1143333NWW. Cleaned the unit and all went fine this is the last time the oven worked prior. Broiler works fine and lites off .Canceled the operation. Cleaning feature works fine an lites off. Canceled the operation. Stove top functions fine.
Remedies I have tried per a repair man. Replaced the electronic module, oven does not function. Because the unit did not bake at the required temp I needed to add 5-10 degrees to the temp setting, I also replaced the temp probe at the same time.
I cannot find a in line fuse nor any other part that has anything to do with the baking cycle. There are no burnt off wires at the terminals. This repair advice i received has cost over $200.00 and still no oven to bake in. If anyone out there can shed some light what I need to do it would be appreciated to get this oven functioning. Thank you ,Don I am basically having the same problem with my oven. I smell a little bit of gas when I try to use the oven and the temperature wont go over 100 now. everything else works fine. Ive had this oven 11 years and never has a problem with it. the endcap came off about a year ago and so the top part of the stove moves a little bit when you push the settings. Not sure if this would have anything to do with this problem. Really cant afford to get a repair person to come look at it. Can you help me.
Originally Posted by: gringa ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I am basically having the same problem with my oven. I smell a little bit of gas when I try to use the oven and the temperature wont go over 100 now. everything else works fine. Ive had this oven 11 years and never has a problem with it. the endcap came off about a year ago and so the top part of the stove moves a little bit when you push the settings. Not sure if this would have anything to do with this problem. Really cant afford to get a repair person to come look at it. Can you help me. Most likely the problem is a bad Bake igniter (#16 on the diagram). It comes without the mounting bracket and you have to use the old bracket. Be careful not to touch the igniter coil. - The Bake igniter Part number: AP4041245
hi gene
amana model no. is ACS7072AS. control panel showing error code F - 1 . please help.
do u know where the reset button or can we just disconnect the noise . we are unable to use the oven at all. but the stove top was fine.
There is no such reset buttons. Most likely the problem is a bad touch pad, but there is a small chance for the control board to be bad as well. - The touch pad (membrane switch) Part number: AP4041648
If you need the correct part number for the control board, post the serial number of the range. Gene.
Boy you are good Gene. The touch pad you sent me is the exact one we have. Ours is still in good condition.
Thanks for your advice on checking the control board. I suspect it's the control board. Meanwhile, will you be able to locate and send me photos like what you did with the touch pad of the control board, I will highly appreciate it. The Serial No. is 0111164270. Manufacture PACS7270ASO. The Model No. again is ACS7072AS.
Thanks a lot!
Thanks a lot Gene.
Gene:
I need another favor. I cant find the part for our microwave just like i cant find the part for the Amana Self Cleaning oven online but you were able to find it for me.
I am looking for the following parts:
GE Microwave
GE Spacemaker - Microwave Model No. J VM240BV 001 Serial No. DR959134S I am looking for the door handle. If you could find me the part no. so that i can order it online.
Maytag Fridge Model No. MBB1956GES MFG No. PMBB1956GSO Serial No. 10051893AL Gene, i just need the part no. for the sliding top freezer tray that so that i can also order it online.
Thanks Gene.
