wrkeels@comcast.net
#1 Posted : Sunday, July 19, 2009 2:01:13 PM(UTC)
wrkeels@comcast.net
Regardless of the cycle (even when set on Low Knits) the dryer heats to excessive temperatures. It may just be that the cooldown cycle is not working. Is there a switch or sensor that can be checked, adjusted or replaced to solve this problem?
richappy
#2 Posted : Monday, July 20, 2009 8:28:00 AM(UTC)
richappy
I would replace the cycling thermostat on the blower housing AP3131939. The output temperature of the drye should be around 145-155 degrees. If the top of the dryer is getting very hot, you probably have clogged ducting.
dryer is too hot! (Dryer Repair)
by lokahiboy 7/20/2011 4:39:50 PM(UTC)
Dryer is too hot on all settings (Dryer Repair)
by klray 6/24/2011 5:09:49 AM(UTC)
Dryer is too hot (Dryer Repair)
by gramparon 1/19/2011 4:16:24 PM(UTC)
by sully 3/27/2008 5:41:33 PM(UTC)
dryer is too hot (Dryer Repair)
by 12wireless 1/7/2008 6:55:10 AM(UTC)
