21 Pages«<89101112>»
rodrigt
#91 Posted : Thursday, July 16, 2009 8:27:47 PM(UTC)
rodrigt
On 09-30-2007 Sailin wrote:
> Oven Codes - Thank you for the oven codes. I do not see F7-E0 under Kitchenaid.....do you have additional information?? Thank you in advance!
Then on 10-04-2007 Admin / APP Team responded:
> This file explains F7-E0 code in detail.
(A link to: https://secured.whirlpoo...6c15a8/$FILE/4317302.PDF )
Thank you, that was very helpful! My KitchenAid KESC307-HBS6 electric range (about 6 years old) suddenly showed up with an F7:E0 error code – Invalid latch switch reading – Check latch switch. And, adding to the fun, repeated testing showed the problem to be intermittent.
I would have never thought that the red plastic part would absorb enough moisture to become conductive and cause a false signal. In my circa 2003 electric stove the Latch Switch assembly was located in the top/center-rear part of the stove (after disconnecting the power cord and removing rear cover). The red plastic (connector holder) part slid out to the right, to unplug from the Latch Switch’s (two) terminals.
Fortunately this red thing provided an easy cut-point, to separate the two connectors (being shorted out, according to the above link). For this I held the red plastic part in one hand and labored with a fine-tooth hacksaw. Next I filled down the cut area and wrapped the resulting two red parts with electrical tape and plugged them back in – hoping this is the end of the F7-E0 gremlin.
[FONT=&quot]PS- AppliancePartsPros has been of fabulous problem-solving help to me and my comments above are in the spirit of making a contribution – Thanks Guys![/FONT]
#92 Posted : Friday, July 17, 2009 2:13:49 PM(UTC)
Thank you for sharing your experience with us. Very instructive information. Good luck with your range.
dlandis1
#93 Posted : Sunday, July 19, 2009 9:39:22 AM(UTC)
dlandis1
Hey Gene,
Again, thanks for your help.
Per the instructions your provided, I was able to verify the wire harness was fine. I volt metered out the 1 and 2 pins on the ESEC board and it was not operating between 4 and 12 volts. I replaced the board yesterday and that has resolved both the F5 and F20 error.
Thank you again!! You saved me a ton in having it repaired.
#94 Posted : Monday, July 20, 2009 8:08:54 PM(UTC)
I'm glad to hear it. Good luck with your range.
ranchingal
#95 Posted : Thursday, July 23, 2009 6:07:30 AM(UTC)
ranchingal
I attempted to use my broiler and oven in the last two days. Kept gettin "F5" error message. I tried this morning and the oven appeared to be preheating. What's the deal?
#96 Posted : Thursday, July 23, 2009 11:38:33 AM(UTC)
If this error code will return I would replace the control board (aka a clock).
- The clock Part number: AP2022868
olallavet
#97 Posted : Wednesday, July 29, 2009 7:07:18 AM(UTC)
olallavet
I did not have an error code on my GE JTP11WP oven but the cold temperature registered 150 and the hot temps were off similarly. Replacing the temp probe, I got error code 3. Reversing the leads made the code disappear but the cold temp is now 280. The sales/tech persons confirmed I had the correct sensor. Where should I look now.
David
#98 Posted : Wednesday, July 29, 2009 12:07:12 PM(UTC)
David,
Most likely the problem is a bad control board. Unfortunately this part has been discontinued by the manufacturer.
Here are the breakdown diagrams and Replacement parts for GE JTP11WP | AppliancePartsPros.com
ranchingal
#99 Posted : Wednesday, July 29, 2009 1:09:50 PM(UTC)
ranchingal
Thanks for your response. I called for a replacement clock. The price is $ 280.00. I think I'll just replace the unit for that price.
Thanks again.
angie
appliance world
#100 Posted : Sunday, September 27, 2009 4:43:22 PM(UTC)
appliance world
whirlpool model# rbs305pdq12 getting an error code e1-f1
Thermador Oven error codes (Oven Repair (including Ranges and Cooktops))
by jblake9000 9/25/2015 9:01:34 AM(UTC)
Oven Error Codes & Won't Heat Fully (Oven Repair (including Ranges and Cooktops))
by davem68 4/18/2013 7:46:23 AM(UTC)
Whirlpool oven error codes (Oven Repair (including Ranges and Cooktops))
by ajsml 9/10/2012 10:21:53 AM(UTC)
by fred jacoby 4/4/2012 9:44:17 AM(UTC)
by sigman 3/23/2012 9:08:14 AM(UTC)
kENMORE OVEN ERROR CODES E3 FI (Oven Repair (including Ranges and Cooktops))
by chrisb361 12/11/2011 3:37:20 PM(UTC)
Whirlpool Electic oven error codes (Oven Repair (including Ranges and Cooktops))
by fcarrelli 9/7/2010 5:56:53 AM(UTC)
Oven error codes F3 and F2 (Oven Repair (including Ranges and Cooktops))
by emidgette 6/1/2010 4:58:30 PM(UTC)
by emidgette 6/1/2010 4:56:50 PM(UTC)
GE Oven error codes (Oven Repair (including Ranges and Cooktops))
by BobChurch 9/1/2009 4:51:40 PM(UTC)
GE oven error codes (Oven Repair (including Ranges and Cooktops))
by bdeinhardt@aol.com 6/25/2009 5:47:37 AM(UTC)
Whirlpool Double Oven Error Codes (Oven Repair (including Ranges and Cooktops))
by alaucks 1/14/2009 9:31:27 AM(UTC)
by cndybkr 9/29/2008 12:13:03 PM(UTC)
Additional Oven Error Codes (Oven Repair (including Ranges and Cooktops))
by indydoug 11/15/2007 6:43:00 PM(UTC)
