A few loads ago Washer originally started making a very load screaching noise in spin cycle......now it also makes noise (though not as loud) when in wash cycle. I checked your blog site first and ruled out the following.......Belt is in good shape; washer drains fine; motor pulley turns smooth and freely; transmission pulley (big wheel) turns freely one way and has resistance the other. The pump pulley turns but not smooth at all.....checked the pump out - no clogs. Even apart the pump pulley is very rough turning............should the pump pulley turn smoothly. Do you think its the pump pulley (pump) that needs to be replaced.
yes the pump should turn easy. with no noise
Thank you very much.....Happy new year!!
