Rheem heater/air conditioner. Heater works fine. When the A/C is turned on, it blows a 3amp fuse on electronic control board inside the heater unit and then the heater won't work. I replace the fuse and the heater now works. If I try the A/C again then the heater won't work. Help !!!!!
Rheem A/C blows a 3amp fuse on the control board when turned on.
You need to check the low voltage wiring for a short. It can be at either inside or outside unit. If the heat and blower work ok its most likely outside. Look for any cuts in the wire insulation and make sure they are not touching any metal on your system.
