keithbrent
#1 Posted : Thursday, June 3, 2010 4:03:52 PM(UTC)
keithbrent
:( checked all hoses and connections to tub - took water pump apart and checked it - machine sometimes still will not drain - after shutting it off for a while it will usually drain -
#2 Posted : Thursday, June 10, 2010 12:12:13 PM(UTC)
Check the wire harness and its connections between the main power board (inverter - #60 on the diagram) and the drain pump.
If there is nothing wrong, replace the main power board.
- The main power board Part number: AP3204590
Dishwasher stops in middle of cycle and has draining problems (Dishwasher Repair)
by Guest 12/21/2022 1:34:11 PM(UTC)
Kenmore Draining Problems (Dishwasher Repair)
by Cenex 9/29/2013 3:24:11 PM(UTC)
draining problems (Washer Repair)
by keithbrent 6/1/2010 5:29:12 PM(UTC)
by keithbrent 6/1/2010 5:25:05 PM(UTC)
Draining problems - Whirlpool GU980SCGQ3 (Dishwasher Repair)
by Mike Moorman 1/15/2008 4:49:24 PM(UTC)
