mpoch
#1 Posted : 15 years ago
mpoch
I have a GE Profile fridge (PFS22MBS) that is experiencing defrost problems. Both the fridge and freezer will hold there temps for a few weeks, then eventually the freezer will start dropping into the negatives and the fridge will start warming up. The evaporation coils are completely blocked with ice. I have to manually defrost with a hair dryer before the unit will hold steady again (only temporary). I have replaced the motherboard and have checked the continuity of the defrost thermostat, reading about 30 ohm and the blue surface is flat. What else could I check for? Thanks for the help with this post.
#2 Posted : 15 years ago
Which part did you call "defrost thermostat"? Can you refer to the numbers on the diagram?
Here are the breakdown diagrams and Replacement parts for General Electric PFS22MBSAWW Refrigerator | AppliancePartsPros.com
mpoch
#3 Posted : 15 years ago
mpoch
Hi Gene,
Thanks for the quick response. The thermostat was number 621, Thermodisc(fuse-m). I have read on other posts that if the blue top is still smooth then it is working just fine. I have also seen that you should be getting a continuity reading of 0-1 ohm, I got about 30. Is this value still good?
#4 Posted : 15 years ago
30 Ohms is definitely wrong reading. It suppose to be close to zero. I would also replace the temperature sensor (#241 on the diagram) and check the defrost heater for continuity.
- The thermodisc Part number: AP3796802
- The temperature sensor Part number: AP3185407
mpoch
#5 Posted : 15 years ago
mpoch
Hey Gene,
So I ordered the thermodisc and installed it. Still having issues. Broke down and had a service technician come in and he assessed the problem as a bad defrost heater. How dificult are these to replace by the homeowner. I got a quote of $460 for parts and labor.
#6 Posted : 15 years ago
The defrost heater is shown as #826 on the diagram. You can get it from Appliance Parts Pros for $120.15
Remove the rear cover in the freezer and look into the evaporator to see how difficult is to replace it. I do not think this part is too difficult to replace yourself.
- The defrost heater Part number: AP3775436
Amana defrost cycle not working (Refrigerator & Freezer Repair)
by rjzzz 15 years ago
Defrost cycle not working (Refrigerator & Freezer Repair)
by macster569 16 years ago
by tottalyoff 18 years ago
