dougt100
#1 Posted : Thursday, May 13, 2010 4:19:51 AM(UTC)
dougt100
Microwave lights up, etc. but does not heat. Makes a "strange" sound.
I'm quite sure that the magnetron is to blame, but I want to make sure that I purchase any other parts; if absolutley necessary. I have seen post/replies regarding a Capacitor and/or Diode (but these are often more resilient and I would assume not need replacing).
Thank you.
ApplianceJunk
#2 Posted : Thursday, May 13, 2010 7:33:55 AM(UTC)
ApplianceJunk
Why are you so sure it's the megnetron that is bad?
Are you even sure it's a problem on the high voltage side?
I replace far more high voltage diodes then I do megnetrons on microwaves that run, but do not heat and make a funny noise.
Diodes are many times cheaper and easier to replace then megnetrons too. :)
dougt100
#3 Posted : Thursday, May 13, 2010 12:43:21 PM(UTC)
dougt100
Thanks for the feedback. I never thought that a diode could cause the problem. Should I just take ohm readings to verify that the diode is good/bad? Not sure what the procedure is...
Are the only two possible "culprits" to non-heating the diode and/or magnetron? Is there anything else to consider?
