Hello My Panasonic Inverter Microwave makes a buzzing sound when not in use? It works just fine but the buzzing is concerning me... Had it for about 2 years and the buzzing started almost immediately. It seems to be more frequent now. Please advise if it should be fixed or replaced. Thank you:confused:
Originally Posted by: paisleymrs ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hello My Panasonic Inverter Microwave makes a buzzing sound when not in use? It works just fine but the buzzing is concerning me... Had it for about 2 years and the buzzing started almost immediately. It seems to be more frequent now. Please advise if it should be fixed or replaced. Thank you:confused: Unfortunately there is no any technical information available on line for Panasonic products. Gene.
There is probably a winding loose in one of the transformers wont hurt anything.. u can use a long tube and put it to your ear to verify which transformer is noisy.. then try some silicone apply small amounts as it will also insulate the windings making more heat.
