freezer side fine,fridge side is freezing up.brand new damper motor,control board says sensor is good.Run damper through operation mode and it will not go to close position.
Originally Posted by: skipd  freezer side fine,fridge side is freezing up.brand new damper motor,control board says sensor is good.Run damper through operation mode and it will not go to close position. If you've replaced the damper door but it will not close, then you probably have a bad damper control, which is not closing the damper door. Make sure that when you perform this refrigerator repair that you dont instead replace the cold temperature control, which controls the unit running time, and not the operation of the damper door.
What part do I need to control the damper in this unit, does it come out of the control board?
Originally Posted by: skipd  What part do I need to control the damper in this unit, does it come out of the control board? Part Details - FRIGIDAIRE Control, part number: AP3763947this is a newer design, the damper control and thermostat control are not seperate on your model, my mistake.
my refrigerator is almost freezing everything putting the control temperature down to lowest setting still frezzing seems colder on top also some frost building where air comes out of vent i cleaned the condenser coils changed settings now three days and still cannot get temperature down.
please help if you have any suggestions or a part that might be bad. The refrigerator is five years old in great condition
