The washing machine was thrown off balance and because of the extreme movement a rubber gasket is now sitting inside the tub instead of where it belongs. My guess is that it goes around the top of the tub but I can't find exactly where it goes. Anyone else ever had this problem?
Thank you, Patrick
Hi patrickhan
The model number you provided is incomplete. It should be 3 digits prefix. Also it'll help a lot if you can post a pictures of the top of the tub of your washer.
