bola300
#1 Posted : Monday, June 23, 2008 8:05:34 AM(UTC)
bola300
It wont turn on and I have replaced the start stop switch and it still wont turn on? I will check everything with the meter but thought I would ask for any suggestions first?
#2 Posted : Tuesday, June 24, 2008 11:41:35 AM(UTC)
The first thing I would do is check the thermal fuse (#7 on the break down diagram) for continuity and replace it if it's open.
If this fuse is blown, it has to be replaced together with the cycling thermostat (#8 on the break down diagram).
- The part number for the thermal fuse is AP3132867
- The part number for the cycling thermostat is AP3131939
Here are the break down diagrams for the Whirlpool dryer Model LER6611LQ0
bola300
#3 Posted : Wednesday, July 2, 2008 7:16:01 AM(UTC)
bola300
Geno you are the man. Your part numbers did'nt coincide but the parts were right on. I check continuity and it was open. Even the 220 outlet was bad. I would recommend you to anyone out there that needs anything fixed. Thanks so much for your help. It cost me 40.00 and I was a minute away from throwing it out and buying a new one. Thanks again. Mark, Illinois
#4 Posted : Wednesday, July 2, 2008 10:51:08 AM(UTC)
You're welcome. Have a nice holiday.
bola300
#5 Posted : Wednesday, March 11, 2009 2:01:35 PM(UTC)
bola300
Hey Geno, I talked to you back in July and you helped me fix my dryer. I have a problem with my ice maker on fridge now. The water that fills up the tray continually runs and does not shut off, it will run all over the inside of the freezer. I have a shut off valve on the back of the unit and it is off but now I have to manually fill the tray. Can you tell me what the problem is and what I need to do to fix it?
Mark
#6 Posted : Wednesday, March 11, 2009 3:25:45 PM(UTC)
Hi Mark,
Most likely the problem is a bad water inlet valve which stuck open. For the correct part number I need the complete model number of the refrigerator.
Guest (5)
DLGX8001W gas dryer clicks on control board but wont start (Dryer Repair)
by Guest 3/12/2023 10:17:53 AM(UTC)
Kenmore 796 40441900 Wont Start, but... (Washer Repair)
by EmitRDetsaw 1/2/2023 11:16:21 AM(UTC)
Replaced belt, idler pulley, and rollers and now Maytag Dryer Wont Start (Dryer Repair)
by Guest 11/29/2022 8:43:07 PM(UTC)
dishwasher lights flash but wont start (Dishwasher Repair)
by markshelp 11/20/2022 8:12:38 AM(UTC)
KMBS104ESS02 wont start. Some buttons unresponsive (Microwave Repair)
by Guest 7/10/2022 1:22:03 PM(UTC)
Kenmore Stacked combo washer wont start after heavy load :( 110.88752796 (Washer Repair)
by puppy10014 10/22/2021 9:23:07 AM(UTC)
my Kenmore Dishwasher wont start (Dishwasher Repair)
by Guest 6/14/2021 8:14:07 AM(UTC)
Samsung dv40j3000ew/a2 wont start after motor replacement (Dryer Repair)
by rev1id 3/24/2021 7:38:30 PM(UTC)
GE Cafe edition Dishwasher Wont start (Dishwasher Repair)
by Lorunner1213 10/1/2019 12:04:27 PM(UTC)
KENMORE Fridge Wont Start Till I punch the thermostat Control (Refrigerator & Freezer Repair)
by kami009 7/5/2019 10:21:20 AM(UTC)
Whirlpool oven & broiler wont start (Oven Repair (including Ranges and Cooktops))
by rstonina 5/13/2019 12:35:09 PM(UTC)
Maytag Dryer wont start (Dryer Repair)
by rscottc 5/27/2018 10:49:05 PM(UTC)
Dryer Elite wont start (Washer Repair)
by pkeresz 4/2/2018 11:06:18 AM(UTC)
Freezer Wont Start (Refrigerator & Freezer Repair)
by curtis68 2/3/2018 1:54:34 PM(UTC)
GE Dryer wont start (Dryer Repair)
by bob35614 2/13/2017 4:21:03 PM(UTC)
