k8fu
#1 Posted : Saturday, June 21, 2008 8:48:35 AM(UTC)
k8fu
I have a couple numbers on my control panel which are inop. Can someone advise me how to remove the control panel on this model ??
I have some spray contact cleaner which I will try first. I'm assuming the panel is attached via a ribbon connector. My next step would be to clean those contacts. If that does not solve the problem any suggestions to repair the pad before ordering another ??
abadfish66
#2 Posted : Saturday, June 21, 2008 9:24:10 AM(UTC)
abadfish66
You need to remove the top vent grille, should be 2-3 screws on top holding it on. Once you remove the grille, you will see 1 screw holding the control panel on
