Rank:: Member
Hi, My dryer timer doen not advance in Automatic heat mode. The timer does advance in timed drying but in either mode there is no heat. I tested the Thermal fuse and Cycling Thermostat for continuity. The thermal fuse is good and the Cycling thermostat has continuity across 2 termainals but not the other two, which leads to my main question. I saw the list of 5 items to check for continuity but how do I know which terminals or wires are supposed to have continuity when there are more than 2 on a part? or can you determine from the information above which part I need to replace. Thanks, Anthony
Do your clothes dry completely on timed dry, or do you have to run it again to get dry clothes?
Rank:: Member
The clothes are not even the slightest bit dry...in my wifes words.
