LVC
#1 Posted : 15 years ago
LVC
My dishwasher has no water entering. It has been washing poorly for the past few weeks (leaving detergent residue and any bit of food that wasn't completely pre-rinsed on the dishes) and then a couple days ago it just stopped washing completely.
I cut the power to the dw, took off the kickplate- and tested the solenoid for the water valve- and it's infinity (no movement on my analog tester). That means it's bad, correct? Am I safe in assuming that the issue lies there? Could there be anything else I need to test or should I just order the part and replace?
I am having problems removing the water line and drain clamp from the valve. Any tips or tricks?
Thank you so much for your help! All of you have been SO helpful... and are saving me a lot of money.
johnobub
#2 Posted : 15 years ago
johnobub
The most likely source of the problem is the water inlet valve.
No water to dishwasher (Dishwasher Repair)
by cejetski 15 years ago
no water to dishwasher (Dishwasher Repair)
by gentry 16 years ago
by hunter 16 years ago
by harbourmain 17 years ago
