Has run flawlessly since new. The other night went to use the dwasher and the power on button switch was dead: cannot power up the machine. I am getting power to the J box.
Any help is greatly appreciated.
Zill.
Gene,
Again thanks for getting back to me. I had a repair guy show up and he confirmed it is the micro switch in the door latch. We said goodbye. I ordered the part which I ahve but the repair man pulled the three wires off the micro switch. Do you have any information about the three color coded wires and which terminal on switch they go to.
thanks very much,
Will.
Will,
The best thing is if you can find the wiring diagram inside the control panel. I found one, but I can not guarantee it is correct. There are three terminals on the switch: COMmon, Normally Open and Normally Closed.
The White/Red wire goes to COM, Violet goes to NC and Gray goes to NO terminals.
