I have a kemore dryer. After running fine heating and drying for about 15 to 90 mins it blows a fuse. I replace fuse and it continues to repeat pattern. Venting is clean and airflow is good. Heating element seems fine. There are no visable burnt wires. motor and drum turn easy. any input would be great tks.
your venting is plugged or your vent is ran to far or has to many bends in it DC repair
Which fuse? House fuse? Dryer's motor fuse? Unit will not start and shuts off. Dryer's heater fuse? Unit runs but there is no heat. |
THIS FORUM IS DEAD!!!!!!! |
