My washer will not complete a cycle without stopping due to a "LD" code. I ran a couple of rinse/spin cycles and the pump seems to be pushing a lot of water into the drain but seems to get hung up in drain cycle after it is empty triggering the LD code. Any help would be appreciated.
I have the same problem and had the pump replaced because that's what the repair man said was wrong with it, but it still does it and we're heading towards the control board. Did you have any luck?
Took my pump off examined tank outlet found bra blocking water outlet from washer tank in our Whirlpool Cabrio washer. Only found it when I reached into the tank outlet with a finger. Wonder if when people take pump off they have to tip the machine which may move stuff out of outlet temporarily:)
