toddy
#1 Posted : Friday, May 30, 2008 5:21:05 AM(UTC)
toddy
Washer starts, then stops. Must be reset and then it runs again then stops.
Will do this 5-6 times to finish a cycle.
Screens are clean and water supply is adequate
Flo
#2 Posted : Sunday, June 1, 2008 2:16:51 PM(UTC)
Flo
:mad: Mines did the same thing until it stop working anymore. I called in a repair service and they said it was the door switch. I had only had the machine for 19 month, using it about 3 times a month!
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Whirlpool Duet Sport wgd8300sw0 - drying time takes forever (Dryer Repair)
by mattyP4321 5/14/2024 8:34:23 AM(UTC)
Whirlpool Duet MDL# WWF8400TW02 New Drain Pump (Washer Repair)
by 1Oskydoodle! 3/30/2024 10:30:29 AM(UTC)
Whirlpool Duet Washer - Possible Faulty Fill Valve (Washer Repair)
by Guest 2/2/2024 4:18:21 PM(UTC)
Whirlpool Duet front load washer model WFW8300SW02 (Washer Repair)
by Guest 12/4/2023 8:39:10 AM(UTC)
Whirlpool Duet electric dryer model WED8300SW1 (Dryer Repair)
by Guest 9/9/2023 9:26:30 AM(UTC)
Whirlpool Duet NG Dryer gas smell when off and open door (Dryer Repair)
by Guest 5/16/2023 4:02:36 AM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
Whirlpool Duet dryer WGD9400 knob Removal (Washer Repair)
by Guest 1/1/2023 8:41:47 AM(UTC)
Whirlpool duet clothes washer (Washer Repair)
by DThiessen 9/28/2022 10:08:52 AM(UTC)
Whirlpool Duet YWED7500VW2 (Dryer Repair)
by Guest 6/14/2022 11:19:46 AM(UTC)
Whirlpool Duet intermittent spinning (Dryer Repair)
by wadeburt 5/17/2022 6:31:21 AM(UTC)
Whirlpool Duet F06 error -- seeking input (Washer Repair)
by TexPat60 2/21/2022 8:25:46 PM(UTC)
Whirlpool Duet ghw9300pw4 has power but no start (Washer Repair)
by 5150 2/18/2022 7:16:37 PM(UTC)
Whirlpool duet washer not draining (Washer Repair)
by Guest 2/16/2022 8:40:23 AM(UTC)
