morgotti
#1 Posted : Sunday, March 14, 2010 6:59:01 AM(UTC)
morgotti
my oven tripped a breaker i reset the breaker now the oven wont heat up but the stove top works just fine
#2 Posted : Monday, March 15, 2010 3:09:18 AM(UTC)
Replacement parts for FRIGIDAIRE GLEF378CQC Frigidaire/electric Range | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316255318.pdf
This may also help
http://frigidaireservicetips.com/pdfs/344_UpdateforElectricFreestandingElectricRanges_Rev.pdf
The wiring diagram does not show any fuses etc. in the oven element circuits so odds are either the control is shot or there is a wire that has burned off.
I am assuming that the control panel seems OK and that you have tried different modes re: bake and broil.
You will have to unplug it and check the wiring.
If all OK carefully check the elements, there is no use replacing the control board unless you are confident that they are OK and not shorting to the frame.
Range oven problems. (Oven Repair (including Ranges and Cooktops))
by jorge osorio 1/29/2019 1:16:21 PM(UTC)
Whirpool Oven Problems (Oven Repair (including Ranges and Cooktops))
by phsffaman 2/15/2014 6:35:40 PM(UTC)
GE Profile Oven Problems (Oven Repair (including Ranges and Cooktops))
by RSF 10/16/2013 10:23:15 PM(UTC)
wall oven problems (Oven Repair (including Ranges and Cooktops))
by jethro75 8/1/2013 6:35:09 AM(UTC)
by jsn.watson1@gmail.com 5/22/2013 8:53:57 AM(UTC)
Jenn-Air Double Oven Problems (Oven Repair (including Ranges and Cooktops))
by goatguns 5/14/2013 7:38:11 PM(UTC)
Jennair Oven Problems! (Oven Repair (including Ranges and Cooktops))
by dazras 3/18/2013 7:03:17 PM(UTC)
Five Star Duel Fuel Oven Problems (Oven Repair (including Ranges and Cooktops))
by menergy 11/20/2012 4:16:12 PM(UTC)
Oven problems (Oven Repair (including Ranges and Cooktops))
by allen9258 10/5/2012 10:11:44 AM(UTC)
Jenn Air double wall oven problems (Oven Repair (including Ranges and Cooktops))
by jetdoc 9/12/2012 5:43:54 AM(UTC)
Whirlpool oven problems... (Oven Repair (including Ranges and Cooktops))
by chappy801 5/31/2012 6:42:47 PM(UTC)
Thermador oven problems (Oven Repair (including Ranges and Cooktops))
by seltzd 4/19/2012 6:13:43 AM(UTC)
by dms 2/2/2012 1:12:14 PM(UTC)
Gas oven problems (Oven Repair (including Ranges and Cooktops))
by Bumpbk 9/19/2011 8:26:32 PM(UTC)
whirlpool gold 465 oven problems (Oven Repair (including Ranges and Cooktops))
by snowfarmer 6/6/2011 2:56:02 PM(UTC)
