nick creekmur
#1 Posted : Saturday, March 13, 2010 2:05:42 PM(UTC)
nick creekmur
nd (not draining error) this model doesn't have the debris filter as in some models behind a small door. Got the water to drain out manually. can't find a part number for the pump. is there a way to test to see if its the motor or the pump itself. I have the pump assembly out. Please help!
Thank you.:confused:
nick creekmur
#2 Posted : Monday, March 15, 2010 3:19:20 AM(UTC)
nick creekmur
I took the pump apart and there was a matchstick preventing the impellor from moving. Removed it and reassembled. It works fine so far! I hope this helps someone else.
edw_jr
#3 Posted : Tuesday, December 14, 2010 9:26:38 PM(UTC)
edw_jr
Think Io might have the same problem. How do I get the pump out??
Thanks.
freska8
#4 Posted : Friday, October 14, 2011 1:02:25 AM(UTC)
freska8
I am having the same problem with my Samsung WF316LAS/XXA. I have replaced the drain pump and it still doesn't work. Does anyone know what could be wrong?
