bowersj
#1 Posted : Saturday, March 13, 2010 10:20:45 AM(UTC)
bowersj
I moved the unit and vaccumed it and now the dryer will tumble the clothes but won't produce any heat. We have checked Fuses/ voltage/ continuity. What next? Thanks:confused:
sidfink43
#2 Posted : Monday, March 15, 2010 6:13:31 AM(UTC)
sidfink43
Check resistance on heating element, it should be in the 8 to 12 range. Also check to make sure all the connections are secure.
It may be that the heating element was brittle and broke when you moved it, our that a loose connection occured from the move.
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
My Dryer Won't Heat (Dryer Repair)
by mell276 12/27/2007 11:45:29 AM(UTC)
