johnc
#1 Posted : Wednesday, May 21, 2008 4:48:04 AM(UTC)
johnc
picked up used side by side for garage. Neather side cools, feels like warm air gently blowing in from vents, compressor running and warm to the touch, fan running, coils and all areas free from dust, no water is being run to unit for ice, any help on what to check before calling in a pro. oh there is also a bluish green fill in the drain pan. Thanks
#2 Posted : Wednesday, May 21, 2008 7:49:59 PM(UTC)
Remove the rear panel in the freezer and check if there is frost in the evaporator. All coils should be covered but not blocked.
If there is no frost than the problem is the sealed system, most likely it is low on Freon.
johnc
#3 Posted : Thursday, May 22, 2008 6:18:59 AM(UTC)
johnc
Thanks Gene, there is no frost but if its low on freon there should be a reason why correct? is it worth haveing freon added or should i get rid of it ?
#4 Posted : Thursday, May 22, 2008 4:05:02 PM(UTC)
If it's low on Freon then there is a leak somewhere in the sealed system.
Such leak must be fixed first and then the system could be charged. It should be done by an authorized technician and it's expensive.
Your decision should be based on the condition of the fridge.
johnc
#5 Posted : Friday, May 23, 2008 4:37:19 AM(UTC)
johnc
thanks Gene !!!!!!!! I will take back in exchange for another.
John
