My washing machine sometimes wasn't spinning and sometimes was having problems agitating. I removed the drive belt and looks good, today I order the belt anyways from AppliancePartsPros.com but is there any adjustment I should know before I install it???
Just make sure the plastic pulleys have no flat spots on them. Also, make sure the motor spring puts tension on the belt, sometimes they fall off. Check the water pump, make sure it turns freely.
