dvleemin
#1 Posted : Saturday, February 27, 2010 10:18:02 AM(UTC)
dvleemin
Hi,
The pilot light in the oven lights, and stays lit, but when I turn the oven on, it does not heat up the oven. If I watch the pilot as I turn on the over (to 400 degrees for example), the pilot flame does get bigger. But that's all that happens. I don't see the burner light.
The top burners in the store top work find.
Any help would be appreciated.
Darryl
dvleemin
#2 Posted : Saturday, February 27, 2010 10:54:36 AM(UTC)
dvleemin
OK,
I did some more testing. If I take a bbq lighter, and while the over is turned on used use it to increase the size of the pilot light, the burner will come on. It will only run for a couple of minutes though before shutting off.
Darryl
