jan and tom
#1 Posted : Thursday, May 15, 2008 7:46:55 AM(UTC)
jan and tom
The gas valve controlls both the broiler and bake in the oven. Broiler works fine but the bake heats really slow, take like an hour to heat to 300. You have the valve in stock just want to make sure that could be the problem.
#2 Posted : Thursday, May 15, 2008 8:39:26 PM(UTC)
Most likely the problem is a bad bake igniter.
Normally it should take no more than 60 seconds to fire up the burner since the oven thermostat turned "on". If it takes more then the igniter has to be replaced.
- The part number for the oven igniter is AP2150412
Here are the break down diagrams for the Tappan range Model 76-4960-23-04
oven safety gas valve sticks (Oven Repair (including Ranges and Cooktops))
by edward goodridge 11/4/2010 10:16:38 AM(UTC)
