Wsaher will not spin. Fills up w/water and agitates but when the spin cycle starts it won't spin. Pulled off front cover found belt shavings in bottom of cabinet. checked motor working fine in both directions. Checked pully for transmission turns freely in CW direction, but CCW direction it's stuck will not move. Also the tub will not move. Possibly bad tranmission? Any help greatly appreciated
Most likely the problem is a bad transmission. - The part number for the transmission is AP2046402 Here are the break down diagrams for the Hotpoint washer Model VBXR2070V0WWGene.
