pchip62
#1 Posted : Sunday, April 27, 2008 9:19:53 PM(UTC)
pchip62
I have a 1989 Jenn-Air slide in range with a broken burner control. I can't figure out how to get to the back side of the control switch to replace it.
#2 Posted : Monday, April 28, 2008 7:16:23 PM(UTC)
The model number you posted does not come up.
Verify and repost it.
Which part did you call "burner control"? Is it an infinite switch on the control panel?
pchip62
#3 Posted : Friday, May 9, 2008 10:28:58 PM(UTC)
pchip62
Yes, it is the infinite switch on the control panel.
#4 Posted : Saturday, May 10, 2008 3:04:25 PM(UTC)
We still need the right model number. If you can post a pictures of the control panel, it might help too.
cs46lee
#5 Posted : Saturday, December 13, 2008 6:37:36 AM(UTC)
cs46lee
I have a model C202 cooktop and infinite control switches. My question is basically the same: do I have to take the whole cooktop apart or can I just lever the little panel out. It only has two screws, which I've loosened, but it seems to stick and I don't want to break it.
#6 Posted : Sunday, December 14, 2008 4:36:22 PM(UTC)
cs46lee,
Remove the air grill (#4 on the break down diagram), remove the two screws holding the control panel (# 1 on the break down diagram), pull the panel outward yourself and lift it up.
Here are the break down diagrams for the Jenn Air stove Model C202
