The plastic handle on my front loader door, I have had to open it with a screw driver, now the bottom of the door is leaking, where can I get a new door?
Use your model number to search on this site, or others if you prefer. After you input it you will be taken to exploded views of your machine.
The model number is the key element here.
Originally Posted by: sidfink43  Use your model number to search on this site, or others if you prefer. After you input it you will be taken to exploded views of your machine.
The model number is the key element here. the model #LTF2140ES
Originally Posted by: sidfink43  thanks, I was able to find that diagram earlier and to get all the parts will cost over $200....
