snudden4
#1 Posted : 15 years ago
snudden4
One of the digits on display for clock, timer and temperature has burned out. If I flick it with my finger, it will return for a moment and then darken again. All the other digits other than the 2nd from the right are fine. For instance, instead of saying 350 degrees, it looks like 3 0 degrees. Any advice is appreciated!
ApplianceJunk
#2 Posted : 15 years ago
ApplianceJunk
Hi,
You could check the board for the clock for bad connection, but chances are you will have to replace it to fix the problem.
snudden4
#3 Posted : 15 years ago
snudden4
Replace the entire board or just a part of it? Is this something my husband could handle or do we need to call a service company? About how much does a board cost? Thanks!
ApplianceJunk
#4 Posted : 15 years ago
ApplianceJunk
Here is the part for your oven.
Part Details - FRIGIDAIRE Clock/timer, part number: AP3853281
Easy enough to change.
GCRG3060AFC Frigidaire Gas Range Timer & Temp Display Error (Oven Repair (including Ranges and Cooktops))
by ChuckCastiglione 4 years ago
HELP! Need clip or nut for Foot on Frigidaire Gas Range (Oven Repair (including Ranges and Cooktops))
by RichardKY 5 years ago
frigidaire gas range (Oven Repair (including Ranges and Cooktops))
by Benitojuarez 7 years ago
Frigidaire gas range will only ignite one at a time (Oven Repair (including Ranges and Cooktops))
by KevinD76 10 years ago
Frigidaire gas range: Bake function inop (Oven Repair (including Ranges and Cooktops))
by Dave1175 11 years ago
Frigidaire Gas Range/Oven (Oven Repair (including Ranges and Cooktops))
by beebem97 12 years ago
Frigidaire gas range control panel--price? (Oven Repair (including Ranges and Cooktops))
by bpjdoc 13 years ago
Frigidaire gas range model fgf379wecs....the oven doesn't always light off (Oven Repair (including Ranges and Cooktops))
by iajet 13 years ago
Frigidaire gas range cook top grates (Oven Repair (including Ranges and Cooktops))
by learjetman 13 years ago
frigidaire gas range oven (Oven Repair (including Ranges and Cooktops))
by repairmann 13 years ago
by larry belanger 15 years ago
Frigidaire gas range display out, oven not working (Oven Repair (including Ranges and Cooktops))
by landas214 15 years ago
frigidaire gas range control dim/not working (Oven Repair (including Ranges and Cooktops))
by kir26 16 years ago
Frigidaire Gas Range wont ignite! Spark Module? (Oven Repair (including Ranges and Cooktops))
by Tractorshaft 17 years ago
by nike 18 years ago
