singlemom
#1 Posted : Friday, April 25, 2008 12:39:05 PM(UTC)
singlemom
I have a side by side with water and ice in the door. The ice maker just quit making ice but the water dispensor still works fine. I took the water tube off the back to check for blocking and it was dry. But there is water getting to the frig. I poored water into the ice maker and it will make ice then but doesn't seem to be getting any water on its own. Please help.....
#2 Posted : Saturday, April 26, 2008 12:23:03 PM(UTC)
The first thing I would check is the water feeding tube into the ice maker for an ice inside. If it's frozen, you can use a hair dryer to defrost it and the water inlet valve has to be replaced in such case.
- The part number for the water inlet valve is AP4298908
