My oven will not light & the ignitors are glowing. The gas stove is working fine. I tried using a lighter & that will not light the overn or broiler either. The gas is not flowing to the oven. What do I check? thanks
The problem is usually the igniter amp draw not the valve. Heres a link on testing the igniter and how it works with the gas valve. service manuals
