this is ge arctica side by side i'm having several different problems with this refrigerator. the frige side gets hot the ice maker doesn't make ice or dispense water & the freezer side also climbs in temp. it does this on & off & then everything goes back to normal (everything works) & then in a couple of days it's starts the same thing over again.can anyone help
thanks curtis
My Fridge Is Doing The Same Thing Again, Does Anyone Has An Answer For Me.
Originally Posted by: soulgong ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) ...i'm having several different problems with this refrigerator. the frige side gets hot the ice maker doesn't make ice or dispense water & the freezer side also climbs in temp. it does this on & off & then everything goes back to normal (everything works) & then in a couple of days it's starts the same thing over again.can anyone help
thanks curtis Curtis, This is a situation which we called "Technician's nightmare" because it is almost not possible to diagnose a problem if it does not show up at time of diagnosis. Also, the problems you mentioned could have a very different causes. Gene.
