abimael64
#1 Posted : Monday, August 20, 2007 2:26:33 PM(UTC)
abimael64
Oven will not turn off when knob is moved to the off position. Have to play with the knob for it to work.
ApplianceJunk
#2 Posted : Monday, August 20, 2007 3:38:34 PM(UTC)
ApplianceJunk
Hi,
Pull the knob off and take a look at the other side of it to make sure it is not cracked.
Kenmore gas oven will not stay at temperature (Oven Repair (including Ranges and Cooktops))
by kosgood 2/13/2021 8:51:55 AM(UTC)
Kenmore gas oven lights but won't get hot (Oven Repair (including Ranges and Cooktops))
by BonnieLC 5/14/2017 5:42:25 PM(UTC)
Kenmore gas oven won't heat up properly (Oven Repair (including Ranges and Cooktops))
by Black Cherry 3/27/2013 11:12:55 AM(UTC)
Kenmore Gas Oven Not cooking evening (Oven Repair (including Ranges and Cooktops))
by ghauptman 12/23/2012 6:47:06 AM(UTC)
Kenmore gas oven not lighting (Oven Repair (including Ranges and Cooktops))
by wingmaster12 11/11/2012 11:11:11 AM(UTC)
Kenmore Gas Oven works only sometimes (Oven Repair (including Ranges and Cooktops))
by Sixmenn 6/21/2010 4:48:50 AM(UTC)
Replacing round igniter on Kenmore gas oven (Oven Repair (including Ranges and Cooktops))
by techmonster 4/24/2010 11:55:57 AM(UTC)
by lexicarl 4/22/2010 9:59:23 AM(UTC)
Kenmore Gas Oven Control Panel replacement (Oven Repair (including Ranges and Cooktops))
by j.clayton 2/12/2010 12:35:45 PM(UTC)
by j.clayton 2/12/2010 12:34:17 PM(UTC)
Kenmore Gas oven burner too high ?!? (Oven Repair (including Ranges and Cooktops))
by 350rocket 10/24/2009 2:33:23 PM(UTC)
Kenmore gas oven doesn't ignite (Oven Repair (including Ranges and Cooktops))
by Jigger 8/24/2009 7:56:24 AM(UTC)
Kenmore gas oven will not turn ON (Oven Repair (including Ranges and Cooktops))
by skidoomxz99 8/20/2009 3:42:25 PM(UTC)
Broken Kenmore Gas oven (Oven Repair (including Ranges and Cooktops))
by jlraatz 3/18/2009 2:33:10 PM(UTC)
Kenmore gas oven display reads 'door' (Oven Repair (including Ranges and Cooktops))
by HandyAndy 3/5/2009 10:08:26 AM(UTC)
