chris77
#1 Posted : Monday, February 1, 2010 8:01:50 AM(UTC)
chris77
The top agitator does not work properly, if at all. It spins in both directions and I am pretty sure it's only supposed to spin one way. Is there any easy solution for this or do I need to replace the entire agitator assembly? I was looking at part #AP3094543 and wandering if this would solve the problem. Does that part come with any instillation instructions? I was also having issues with separating the top and bottom agitators from each other. Should they just pull apart?
#2 Posted : Tuesday, February 2, 2010 2:26:19 PM(UTC)
The agitator repair kit Part number: AP3094543
should solve the problem. The instructions are attached to the reply.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LSQ9010LW2 Automatic Washer | AppliancePartsPros.com
File Attachment(s):
Agitator dogs - trust washer.pdf (103kb) downloaded 7 time(s).
Top agitator not working properly (Washer Repair)
by chris77 2/1/2010 8:04:51 AM(UTC)
