I have a wall oven and when I open the door the inside light comes on and then it goes off once I close the door. Every once in a while, even though the oven door is closed the light goes on by itself. When I push the door in a little the light goes off. I think the door is not closing all the way. Any one with advice??????
Rank: Administration
Groups: Joined: 7/18/2007(UTC) Posts: 799
Sounds like the door is not aligned properly. Do you have little kids? Do they like to hang or sit on the door? (Don't laugh, pretty common :) ) Check the door and door hinges. - Door diagram for W30400PC
Possible corrosion on, poor connection on or faulty socket
